Hello AJ Sebstian, I have tried your solution and have linked 2 databases in one Innovator Instance. On my default database I have no problem using vault, yet when I switch to 2nd database I am not able to open files. How do you "connect:" database to vault ?
Best regards
Lukasz
Hi LukSor,
Each database has it's own vault by default. This can be found (default location) at c:/aras/vaults/[DBNAME]. If you've added a second database it's looking for a vault at that location. Unless you've manually created one, it won't exist. For testing purposes, the easiest path forwards is to create a copy of the vaultfolder and rename it the same as your new database.
AJ
- LukSor5 years agoIdeator I
Hello again, thanks for your last reply.
I have installed second instance of Innovator. One works on https, second one on http.
Do you know if is it possible to setup Agent Service and Conversion Server for the second instance ? They work ok on original environment.
- asebastian5 years agoCommunity Manager
Hi LukSor,
It is definitely possible, the important part is making sure you are installing the Agent Service components when you're installing your second instance. You'll have to set up a second Agent Service with a unique name.
AJ
