Hi Moaud,
Assuming you're making/testing the changes in the same instance, I would recommend clearing your browser cache. It shouldn't make much of a difference unless you're modifying code tree files, however it's always one of my first steps when troubleshooting a client-side error or any strange behavior.
But to answer your question, there shouldn't be any additional requirements to have to parallel innovator instances running on one machine. Have you tried creating the client event in both instances? Does it work in one, both, or neither?
AJ
Hi AJ Sebastian,
I have tried creating the client event (alert) in the first instance already installed and it's works fine, but it's not working in the second instance as i didn't see any changes even if i clear the browser cache.
Is there any other idea please ? as i'm still stuck on this.
- mouad6 years agoCreator I
Note that i have tried to add " debugger; " to the client method as you see in the screenshot below and nothing happens.
but when i add the client method to the form (Part) of the itemType Part it's works fine with or without debugger option.
- asebastian6 years agoCommunity Manager
How are you executing the client method? What kind of client event are you attaching it to? Is it configured identically in the first instance?
Hi AJ Sebastian,
the client method executed by clicking in the category concerned then the button with the event onFormPopulated.Note that the IemType concerned is no longer displayed in the category in the TOC Pane and the list of categories does not show the category of the ItemType in question.
