Hello AJ Sebastian,
I have done the needfull, the second instance installed successfully but i am unable to see changes when i execute a client Event method.
Server event method works fine as when i execute the method i can see the changes.
I have tested with a simple client method that contains just an alert but no changes are applied in the application.
Is there any missing configuration shoud be done ? as this is so strange
- asebastian6 years agoCommunity Manager
Hi Moaud,
Assuming you're making/testing the changes in the same instance, I would recommend clearing your browser cache. It shouldn't make much of a difference unless you're modifying code tree files, however it's always one of my first steps when troubleshooting a client-side error or any strange behavior.
But to answer your question, there shouldn't be any additional requirements to have to parallel innovator instances running on one machine. Have you tried creating the client event in both instances? Does it work in one, both, or neither?
AJ
- mouad6 years agoCreator I
Hi AJ Sebastian,
I have tried creating the client event (alert) in the first instance already installed and it's works fine, but it's not working in the second instance as i didn't see any changes even if i clear the browser cache.
Is there any other idea please ? as i'm still stuck on this.- mouad6 years agoCreator I
Note that i have tried to add " debugger; " to the client method as you see in the screenshot below and nothing happens.
but when i add the client method to the form (Part) of the itemType Part it's works fine with or without debugger option.
