8 years agoAccelerator III
Given an Excel file like so:
A B C lt_oem_code lt_oem_name description VW Volkswagen A description & more GM General Motors Another descriptionYou could write the following formula in cell D2 and then copy it down.
="<Item type='LT_OEM' where=""lt_oem_code='" & SUBSTITUTE(A2,"&","&") & "'"" action='merge'> <lt_oem_code>" & SUBSTITUTE(A2,"&","&") & "</lt_oem_code> <lt_oem_name>" & SUBSTITUTE(B2,"&","&") & "</lt_oem_name> <description>" & SUBSTITUTE(C2,"&","&") & "</description> </Item>"Then, within Innovator Admin paste all of the
<Item> queries into the window and wrap them in an <AML> tag such as
<AML> <Item type='LT_OEM' ... <Item type='LT_OEM' ... <Item type='LT_OEM' ... <Item type='LT_OEM' ... </AML>Then, use the menu next to the Run button to select Run Batch… to execute the AML in reasonably-sized batches to optimize performance. Hopefully that helps. If not, let me know.
