8 years agoAccelerator III
Unfortunately, there is no such functionality currently. The reason is that creating a UI that is both simple and powerful for transforming a file into AML is complicated. What I generally do for this is
- In Excel, create a column next to the data that contains a formula which generates the AML. The one caveat with this approach is that you need to remember to properly encode your values (e.g. replace
&with&). If you are starting with a SQL table, you could also write your SQL statement to generate AML with the same caveat. - Once you have all of your AML, paste it into Innovator Admin inside of a single
<AML></AML>tag. - Use the menu next to the Run button to select Run Batch... to execute the AML in reasonably-sized batches to optimize performance
