Hi mym607,
Please let me know if I've misunderstood your question. To get the ID of a specific ItemType that you'd find on the TOC (EX: Part), here are the steps.
Log in as Admin
In the Administration section of the TOC, perform a search on the ItemType ItemType
Search for the Part ItemType
Right-click on the Part result in the search grid and select properties
Copy ID button.
If you're looking for a specific Item ID, the process is essentially the same. Every Item has a properties page which contains the ID of the item, and this also counts for ItemTypes, because everything is an Item.
AJ
Is it possible to implement JavaScript code?
- asebastian6 years agoCommunity Manager
I'm not sure exactly what you're looking for. If you wanted to get the id of a specific itemType in a JS method, you could do something similar to the following:
var newItem = inn.newItem("part","get");
newItem.setProperty("name", {YOUR ITEMTYPE NAME});
newItem = newItem.apply;
var id = newItem.getID();
This can get whatever ItemType you're looking for and extract the ID. Let me know if I've misunderstood your question.
