Primoz
7 years agoIdeator I
Hi Angela,
I went througt your solution and you defined well the basic for the Resource Management in ARAS. Good job. You added also some visualization, which is very important in my case.
My use case should support the visualization as an overview of the Resource planning/spending through the projects (active or/and pending) including several filters (like: by project, by team (defined from multiple Resources), by resource, by date range, etc.).
To support this use case I checked the "Resource Chart" control (Dojox.Gantt control).
link: archive.dojotoolkit.org/.../test_Gantt.html
Is that kind of the visualization relevant for your use case?
Regards,
Primož
