asebastian
7 years agoCommunity Manager
Hi Archan,
I am unable to recreate this behavior in my own environment. To learn more about the issue you could use server debug logs to better understand where this error is coming from. A blog written by labs regarding server debug logs can be found here. Is this issue happening on all requirements, or only ones you're adding through AML?
AJ
archan96
7 years agoIdeator III
Hi AJ,
This issue is happening on all requirements, added through AML and through UI as well.
