jeromecha
6 years agoCreator I
Document promotion by DCO
When a DCO change status from New to In work, the affected documents change their status to 'In change'.
Where is defined this document status change ? In the DCO workflow ?
Thanks .
Thanks .
Hi Jeromecha
It should be defined in method PE_ChangeItemTransition. In DCO workflow promotions tab on In Work activity, open the attached promotions and you will see the pre method attached to that activity.
Thank You
Gopikrishnan R
Great Gopikrishnan !!
I found the method PE_ChangeItemTransition.
Note : In my version (12) this method is attached to the liclecycle DCO not to the workflow.
Thank You .
