R_Creator I9 years agoDate Problemhii i have one item type QDM having field which datatype is date and pattern is shortdate i select 4/28/2017 date where 4 is month , 28 is day and save item then i open sql server and open data ...Show More
pwillemsenIdeator II9 years agoIt could be a mismatch with the server date. You may want to check what date (and time) is actually stored in the database in both cases.
Recent DiscussionsSolid Edge derived part (Part Copy of a Part Copy) → empty 3D viewable, conversion task "Succeeded"virtualGetForm 404 when accessing Aras through Nginx[ARAS 14] Change display order of authentication optionsaras plm 11.0 -Authorization code verification failed(AP-00006...)SolvedException of type 'Aras.Server.Core.InnovatorServerException' was thrown.
