Hi Gopikrishnan,
I don't think that i missed something as this is the first step to do (importing the AML packages) after the installation of agent service and Data Synchronization Services Application
Hi mouad,
Which version of Aras Innovator are you using?
- mouad6 years agoCreator I
Hi Chris,
I'm using Aras innovator 11 SP15- christopher_gillis6 years agoCommunity Manager
Hi mouad,
I tested this in a local 11.0 SP15 instance, but I wasn't able to reproduce this issue. Gopikrishnan is likely right there is some ItemType referenced by this package that does not exist.
Could you confirm that the ConversionServer is also installed per the prerequisites? For more details about this error, you can also check the logs of the import tool to find which query exactly is causing the error. This should help us track down what the missing reference is. You can check this in the /logs/ folder that should be in the same location as the .exe of the Import tool.
The best way to generate these logs is to delete any existing logs, run the import again to cause the failure, and then check the resulting log file that's generated. This will help minimize the amount of information that you have to look through. The query that's causing the error should be near the bottom of this generated log file.
