- Nithin_MaheshCreator II
Hi Haider,
Assuming you are creating a report built on XSLT, I think the best way would be to create a server method to compare the item numbers between Projects and ECN's. Then add a conditional that will generate the XML when these two are equal. This can be then passed to the XSLT to be populated. You can also probably compare them with xpath properties in XSLT, but it would be easier in a C# method.
Best,
Nithin
