Gopikrishnan
7 years agoAccelerator II
By keeping ServerEvents='0' in your batch script will prevent running the server events while execution.
dortego
7 years agoIdeator III
Thank you for your response. I tried setting serverEvents='0' in AML template file for the ItemType, but it made no difference. Do you mean set the serverEvents flag inside the batch script itself (.bat file, where the BatchLoaderCmd command is called)? I'm not sure how that would be done.
- Gopikrishnan7 years agoAccelerator II
Can you please confirm what is the onbeforeAdd event is doing?. Also please validate the input with the list values if you have any.
