7 years agoCommunity Manager
- Could you confirm if MPP was working prior to the installation of the Variant Management sample app? If so, could you confirm that you installed this release of the sample app which was written for 11.0 SP12 specifically?
- In regards to your QMS installation, could you confirm if you have PE 11.0 R3 installed in your system? This is a pre-requisite for installing QMS. Additionally, you can uncheck the Optional Office Connector Settings when selecting which features you want to install unless you specifically have the Office Connector installed in your environment.
- venkatsai7 years agoIdeator III
Hi Chris,
Thanks for your response. i think i installed Master branch which is for SP15, i removed and installed which for SP12, After that, magically QMS also installed. Thanks alot Chris.
