I'm not sure what you mean by an "orphaned" changed controlled item, but there's a couple different ways to search for them. If you're trying to add this item to an ECO anyway, the easiest way to do this would be to simply add a new affected item to the ECO's Impact Matrix. This launches a search dialog that lets you search on all of the Change Controlled Items in your system.
Alternatively, you can add a TOC Access relationship to the Change Controlled Item ItemType to let you search for these items in the main grid. To do this...
- Login as admin
- Navigate to Administration > ItemTypes
- Search for and open Change Controlled Item
- Edit this item
- Navigate to the TOC Access relationship tab
- Pick an identity that should be able to see this item in the TOC
- Choose a folder for this item to appear in in the TOC
- Save the ItemType
Now you should be able to select this item from the TOC to perform a search in the main grid.
