Hi Harien
You can use merge action in batch loader also
Create an EXCEL file with columns title, start_date, end_date and status
Fill the Values in excel
Save Excel file as text tab limited file
Example:
| title | start_date | end_date | status |
| 523556 | 2019-09-30T00:00:00 | 2019-09-30T00:00:00 | New |
| 523556 | 2019-08-30T00:00:00 | 2019-08-30T00:00:00 | Closed |
| 523556 | 2019-07-30T00:00:00 | 2019-07-30T00:00:00 | Released |
| 523556 | 2019-06-30T00:00:00 | 2019-06-30T00:00:00 | New |
| 523556 | 2019-05-30T00:00:00 | 2019-05-30T00:00:00 | Active |
| 523556 | 2019-04-30T00:00:00 | 2019-04-30T00:00:00 | Active |
Create a XML file with below query and save as AMLQuery.xml
<Item type='myItem' action='merge' where="[myItem]._title='@1'">
<_start_date>@2</_start_date>
<_end_date>@3</_end_date>
<_status>@4</_status>
</Item>
Steps to load multiple Part BOM using Batch Loader are
Open Batch Loader.exe (Available in ARAS Installation CD)
Select ‘New’ in Batch Loader
Update the below parameters in Batch Loader
• Server : ARAS URL (Example : localhost/InnovatorServer
• Database : Innovator Server (Select from the drop-down menu)
• User : root
• DataFilePath : inputfile.txt (Select the input file)
• Delimiter : \t (Select tab delimiter)
• WorkerProcess : 2
• Threads : 4
• LinesPerProcess : 100
• Encoding : Unicode (UTF-8)
• FirstRow : 1
• LastRow : -1
• LogFilePath : outputfile.txt(Create any text file and select)
• LogLevel : 2
• PreviewRows : 1000
• MaxColumns : 10
• FirstRowColumnNames: False (True in case if input file has header)
Click load and select AMLQuery.xml
Click Verify and provide the root password
Verification Message: Verification successfully Passed: the template does not contain invalid item types or properties.
Click Load
This should work.
Thank You
Gopikrishnan R
Thanks it worked perfectly !
