You can set permissions on a subclass using OnBeforeAdd and OnBeforeUpdate server events on the desired item.
You should be able to use the same method for both events.
In the method, check to see if the item has been set to a certain subclass.
If so, set the permission.
Below is some example code to get you started:
Aras.Server.Security.Identity plmIdentity = Aras.Server.Security.Identity.GetByName("Aras PLM");
bool PermissionWasSet = Aras.Server.Security.Permissions.GrantIdentity(plmIdentity);
try
if (this.getProperty("classification", "") == "Assembly") {
Item permission = this.newItem("Permission", "get");
permission.setProperty("name", "Assembly Part");
permission.setAttribute("select", "id");
permission = permission.apply();
if (permission.isError()) {
return inn.newError("Could not obtain Assembly Part permission. " + permission.getErrorDetail());
if (this.getProperty("permission_id") != permission.getID()) {
this.setProperty("permission_id", permission.getID());
finally
if (PermissionWasSet) Aras.Server.Security.Permissions.RevokeIdentity(plmIdentity);
return this;
Hope this helps :)
Jillian
