tejaswini's avatar
tejaswini
ARAS 12 Installation Error
while installing ARAS 12 I am getting below warning:
CANNOT CREATE CORRECT OAUTH SERVER.
After that Installation completed.But while login to ARAS 12 Below error will come
Do anyone know what to do?
  • Hi Tejaswini,
    Did you get an error during installation stating that the OAuth server config or web file was not created? If that was the case I would check the following:
    1. Make sure you have the correct .net core and asp.net core installed
    2. Check your environment variables to ensure that path points to the installed .net
    Best,
    Nithin
