- Skyler_CrossmanCreator II
Tim_Beard,
The dot is a styling artifact, the result of a dropdown menu with zero elements in it. That Actions dropdown exists in the toolbar because there might be some action you could take based on the item you have selected in the tree- if there was, you'd see the available actions when you clicked the dropdown. That toolbar doesn't necessarily know which items you'll have underneath it, hence the presence of an Actions dropdown that (in this circumstance) has no items. No actions are unavailable to you, there just aren't actions for that item.
As for why the styling artifact shows up as a little dot instead of something like "no actions available", that I don't have as good an answer for. More recent CUI elements lack it, so I suspect it's likely to disappear as old elements are phased out in favour of new, but I don't have any particular timeline on that.
Skyler C.
- Tim_BeardIdeator III
Hi Skyler,
Thank you for the explanation! Makes sense. I'd seen a similar artefact with the Unused Properties drop-down when building forms, but had worked out how to fix that.
I had hoped that there was an option in the Action menu to export the project tree to Word or Excel. Using the export functions at the top of the screen only exports a single line. The export to PDF is OKish, but does not allow for further formatting, or exporting from there to Word or Excel (all the text is gibberish). I've seen a export project in github, but it didn't seem to do anything for me.
Thanks again,
Tim
Tim,
This one? (https://github.com/ArasLabs/project-plan-excel-export) The project plan is a bit unusual, but the community project was designed for it. It should add a button to export to excel in the toolbar. If it doesn't seem to do anything, it might need updating. (It was my first community project, so I'm a little attached to it!) Do you see no new button at all?
Skyler
