jamar's avatar
jamar
9 years ago
Access the system using the URL
Hello, Does anybody know if it is possible to access the system using a URL from .Net code? For instance when coding with .NET or other languages to access a website you simply add the URL into the code. Is there a way to do this in ARAS to access a specific part? Understandable you would need the login information (possibly in a separate txt file?). I am having trouble understanding how the url is made up in order to access it. Set IE = CreateObject("InternetExplorer.application") Navigate site1= "http://www.google.co.uk Thanks
  • Hi, Sounds like you are refering to a REST interface where every ressource can be reached via an URI. It is not yet available in Aras. Out of the box we provide:
    • a SOAP interface where you need to use AML
    • you can also use the .net API for your .net projects
    • if you are a subscriber we still support our WSDL packager tool.
    Can you share what you are trying to achieve? maybe we could give you some hints?
  • jamar's avatar
    jamar
    Thank you for getting back to me. I have now been able to access the system through the api to achieve the desired results. The URL was more of a long way round.
