eli_donahue
7 years agoCommunity Manager
Hi rdraut,
It sounds like there may be a conflict somewhere between the HTML to PDF Converter/Publisher, the CAD to PDF Converter, and the hotfix for MPP. I recommend contacting Aras Support ([email protected]) with this issue, as they will have more details about the hotfix and underlying issue.
Eli
Eli Donahue
Aras Labs Lead Engineer
- rdraut7 years agoIdeator II
Thanks! The hotfix is installed but there are some issues with dll versions when a clean Innovator 11.0SP12 instance has MPP11.0R3 installed. Conversion server works fine, but not for MPP process plan publishing. Support gave us one proposed workaround but it results in another error.
