Technical Document Numbering Issue
Hello Community, While creating a Technical Document, I added a Chapter which was numbered correctly as 1. Under this Chapter, I created a Section which was numbered 1.1, and everything worked as expected up to that point. However, when I added another Section under the same Chapter, it was numbered as 2 instead of 1.2. Both sections are created under the same Chapter, so the second section should ideally follow the hierarchical numbering sequence as 1.2. Is there a fix for this issue, or am I doing something incorrectly in the configuration59Views1like0CommentsTDF - Change an Element to Different Schema Type (Text > Heading)
Hello All, Has anyone come up with an easy way to convert one DocumentSchemaElement into another one? We are dealing with importing Word documents into Tech Docs and rather than trying to hard-code in all the possible different style scenarios we're looking at some sort of CUI element to click a document node and then convert it to something else. Examples: Text to a Chapter or Section Text to a List Item There's a 'Replace Item' OOTB action, but I'm just curious if anyone has looked at swapping an element type. Example from OOTB below. Thanks in advance!34Views0likes0Comments
