Technical Document Numbering Issue
Hello Community, While creating a Technical Document, I added a Chapter which was numbered correctly as 1. Under this Chapter, I created a Section which was numbered 1.1, and everything worked as expected up to that point. However, when I added another Section under the same Chapter, it was numbered as 2 instead of 1.2. Both sections are created under the same Chapter, so the second section should ideally follow the hierarchical numbering sequence as 1.2. Is there a fix for this issue, or am I doing something incorrectly in the configuration59Views1like0Comments
