MAC Policy Issue in ARAS 31 – Need Help with Access Restrictions
Hi all, I’m working on implementing access restrictions for the a Itemtype in ARAS 31. There are around 46 records, and I want to group them into 5 categories. Each category will be assigned to specific identities, allowing controlled access based on the record's classification. To achieve this, I started configuring MAC policies. However, I’ve run into a few issues: The fields I need are disabled in the MAC Policy Condition Editor. User-defined properties are not accessible in the condition editor either. Has anyone faced similar challenges or found a workaround for this? Any help or guidance would be greatly appreciated! Thanks, Salini193Views0likes2CommentsIs it possible to use the System Event Log for logging custom events?
Hi community, the system event log by default is configured so we can track successful and failed login attempts. I wonder if we can also use the log to track other events of interest? E.g. I have a few C# Methods where I want to track when and how often the Methods fails. I have added a custom SystemEvent type for "MethodFailed". But when I use the following code, I will get the following error message: "Requested value "MethodFailed" was not found. CCO.SystemEventLogger.CreateSystemLogRecord("MethodFailed","Method_doSomething",inn.getUserID(),"Method xy failed, value z invalid" ); This line of code in a C# Method only works, when I use one of the standard OOTB system events: CCO.SystemEventLogger.CreateSystemLogRecord("SuccessfulLogin","Method_doSomething",inn.getUserID(),"Method xy failed, value z invalid" ); Is it possible to use own system events types at all? If yes, where do I have to add my custom event type? Or maybe someone know some other log options? I don´t want to build a separate ItemType for this use case. The System Event log would fit very well, cause it is checked and cleared on a regular basis anyway. Would be cool if somebody has an idea how to solve this one!Solved10KViews0likes5Comments
