Relationships and Reports
Good day all. I am going through our Aras trying to understand what is going on with it. We inherited this from another contract. The previous caretakers created their own ItemTypes and didn't use any of the default ones. We are trying to run a BOM report on parts, but are getting errors with it. I have been looking at the Part ItemType & the s_Part ItemType (what is being used) to identify the differences and try to get things to work. Here is where I am at. The custom s_Part is using a "Parts List" instead of the BOM that the Part uses. One of the differences I have noticed between these is that the BOM is a relationship back to Part & the Parts List is a null relationship. When I run the custom BOM Quantity report, I receive a parts list with how many of each component is required. If I run it from too high of a level (example: Antenna Group) I receive an error that indicates that I do not have permissions. The next lower assembly (Antenna Array) will work. The custom Multilevel BOM reports cause the system to crash. I was reading through the article for creating Queries, but it doesn't work for our setup. I think this is do to the null relationship. Any help would be greatly appreciated. Thank you.5.5KViews0likes3CommentsCage Code 00000
Good day all. Would having a Cage Code of all 0's cause a problem when a report is ran? I receive errors for some of my parts reports that indicate that I do not have permissions to run the report (I'm an Admin). When I try to run the report from the parts attached to the part that causes an error, I can run the reports with no problems. I'm trying to figure out what is causing the problem. This is a custom report to generate a BOM. The BOM lists have included parts and a few different types of documents. I have inherited this system from a previous contract, so I am trying to figure out how it was set-up and what exactly it is doing. Thanks for any help you can provide. An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for dataset 'DataSet1'. ---> System.Exception: For more information about this error navigate to the report server on the local server machine, or enable remote errors11KViews0likes8Comments
