Graph Navigation
I am trying to set up Graph Navigation as per below documentation https://community.aras.com/b/english/posts/getting-started-with-graph-navigation But after adding the graph view to an itemtype. i set all the required as per documentation . when i open the Graph i see screen as mentioned below But i wanted to get rid of those ARAS ID's marked in yellow , i just want structure to be visible. can you help me fix it5.5KViews0likes3CommentsSelf Service Reporting
Hi ARAS Experts, I have a question. I have been building some Self Service Reports in an ARAS 11 instance. I think that they could be very useful in our Environment. I have the following questions: Can I E-Mail a URL to the Report. If so how? ( I dont want to use exported pdf ect, I like the dynamic nature of the Report within ARAS) Can I link each row in the table to the associated Item so that it will open up within the same ARAS instance. In "Properties", I have played with the advanced property Settings. I can turn an entry in the table to a Hyperlink that will open a specific Item (FQDN), what I cant do is put the right variable in the URL to link to the associated item.5.6KViews0likes4CommentsFMEA Reports
Hello, Has any one Developed any report for FMEA using query builder? Assume a Program Object(Custom) Connected with 20 FMEAs which has 2 custom Properties Sub System and Components Use Case is 1 . Create a Report which will take input as RPN > any Number (Example : RPN>40 or RPN>85 etc) and give a report of each lines of FMEA which has matching criteria (RPN> number) . Report Should have Export to excel option. 2. Show the top 50 Critical lines for the Program .That means show a report with all lines having top 50 highest RPNs. I tried Creating this report by writing Custom Code where report is static one and i hard Coded the value in Code with RPN>40 . Also this does not have Export to Excel available. Question is can this report be generated using Query Builder ? Or Self Service Reporting tool will be of any help to build this kind of dynamic report ? Thanks Smruti6.3KViews0likes3CommentsSelf-Service Reporting Questions
Our business is wanting to start reporting more frequently. I have found that Self-Service Reporting is time-consuming and somewhat troublesome to use...not to mention slow. I have a few questions for those who use the Self-Service Reporting tool in Innovator: Who creates the self-service reports for your business? Is IT involved? Is it a full-time resource? What is the volume of requests for new reports? What areas/ItemTypes of Aras are the reports generated? What is the magnitude of the reports? (i.e. do you have many specific reports for whoever requests them or do you have just a few broad datasets that users can then run filters on to suit their needs?) If you do not utilize Self-Service Reporting, what reporting mechanism does your business use for users to measure metrics, etc? Thank you, in advance, for your response. Wes4.9KViews0likes1CommentReports Exporting an Excel file instead of Displaying HTML
Hi, I'm quite new to AML and XML and Innovator Reports. The default reports in Innovator 11 SP9 generate a HTML page containing all the data, however is it possible to instead make it generate an Excel file for downloading containing the same data instead of a HTML page? Thanks4.7KViews0likes2Comments
