Can we add multiple reverse relations targeting a single relation?
Hi, We have the following scenario: I have a custom itemtype which has relationships with different itemtypes like Part, Requirement, etc. Now I want to show the reverse relation on my custom item type pointing to Part and Requirement. On custom Itemtype we have one relationship that has the source itemtype as custom itemtype and related itemtype is null. On this single relationship can we add reverse relation using a Relationship View for both Part and Requirement, and more? If yes, how to add more than one Relationship View? Or if there is any other way that leads to showing the different itemtypes relation using a single relationship? Thanks in advance. Best regards Tanjum127Views0likes1CommentRelationships and Reports
Good day all. I am going through our Aras trying to understand what is going on with it. We inherited this from another contract. The previous caretakers created their own ItemTypes and didn't use any of the default ones. We are trying to run a BOM report on parts, but are getting errors with it. I have been looking at the Part ItemType & the s_Part ItemType (what is being used) to identify the differences and try to get things to work. Here is where I am at. The custom s_Part is using a "Parts List" instead of the BOM that the Part uses. One of the differences I have noticed between these is that the BOM is a relationship back to Part & the Parts List is a null relationship. When I run the custom BOM Quantity report, I receive a parts list with how many of each component is required. If I run it from too high of a level (example: Antenna Group) I receive an error that indicates that I do not have permissions. The next lower assembly (Antenna Array) will work. The custom Multilevel BOM reports cause the system to crash. I was reading through the article for creating Queries, but it doesn't work for our setup. I think this is do to the null relationship. Any help would be greatly appreciated. Thank you.5.5KViews0likes3CommentsGet Related Item from a Form.
Hi Can somebody please help me understand how to get a Relationship Item from a Form Method. I have tried getReleated Item but it doesnt seem to work for me. I want to run a method on Click.So when a User clicks that button it should open up another form and from there it should allow them to add information on to a related Item. Can somebody please advise me on this. Any help will be great. Thank you in advance.4KViews0likes1Comment
