TDF - Change an Element to Different Schema Type (Text > Heading)
Hello All, Has anyone come up with an easy way to convert one DocumentSchemaElement into another one? We are dealing with importing Word documents into Tech Docs and rather than trying to hard-code in all the possible different style scenarios we're looking at some sort of CUI element to click a document node and then convert it to something else. Examples: Text to a Chapter or Section Text to a List Item There's a 'Replace Item' OOTB action, but I'm just curious if anyone has looked at swapping an element type. Example from OOTB below. Thanks in advance!30Views0likes0CommentsRequirements Document: Error from Editor?
Hello, Aras Ver. 12 For a Client we have had to customize the attributes for Requirements and Requirements Document objects. No changes at the moment have been made to the XML schema. Requirements Documents can be created, but as soon as the user clicks on the "Requirements Document Editor" they get the below error: We've made no changes or edits to the schema. Is it necessary to make changes to the XML schema when adding properties to requirements? We did create a Class for the requirements document; however this appears whether the class is assigned or not. Appreciate any assistance!2.2KViews0likes3Comments
