Refresh challenge of CommandBarSectionItem - Dropdown
Dear Aras community, This is my first discussion thread, so please let me briefly introduce myself. I am the team manager of a small CAD/PLM team at a German company, and we recently managed to transition from a 20‑year‑old PLM system to a new one that all of you should know. We went live in December 2024, and little by little the Aras fan base in our company is growing. 1. UseCase introduction We handle many of our customizations ourselves, and we make extensive use of Aras Program Management. To track the work we do for our customers, everything needs to be linked to a customer project. That’s why we implemented a project_origin_id on every relevant business object (Part, Document, CAD, ECO, and other processes). If a user is connected to a project, then anything they add (create) is automatically associated with that project. This is visible through relationships on the Project ItemType. Users can connect themselves to a project via an action on the project called Assign Project Context. Now, after more than one year of running the system in production, we want to improve this feature for changing the project context. The idea is to have a dropdown list that displays every relevant and active Project item. When the user selects a project from the list, the OnClick method will attach the user to that project: (user.project_context_id = dropdown.value). In the following screenshot you will see our implementation so far: 1: should refresh the list (2) 2: dropdown list with all relevant customer projects 3: opens the current selected project in a new tab 4: detach the user from the project and should refresh the list (2) 2. The challenge The dropdown initialization and the OnClick method work as expected. However, we are facing a very frustrating challenge: the dropdown list needs to be refreshed whenever Button 1 or Button 4 is clicked. Unfortunately, we have not been able to implement this. At the moment, the dropdown list is only re‑rendered when the user logs in to Aras. 2.1 Include Events We could identify that the Command Bar Section Item of the dropdown item has a configuration field which is called IncludeEvents. When you select an event named Update State than the dropdown list gets initiallized too often: Perform a search on an random ItemType -> 4 x dropdown init gets started Perform a refresh an an random ItemType form -> 2x dropdown init gets started Switch tabs -> 2x dropdown init gets started Commit a change on a random ItemType -> 2x dropdown init gets started Because of performance issues we can not use IncludeEvents. 2.2 Initialiaze Dropdown We did manage to initiallize the dropdown when other Buttons gets clicked. But the values and labels does not gets rendered in the dropdown item. Below you see our code example for Button 1 (refresh). let dropdown = control.data.get("user_project_scope_list"); // Name = Name des CommandBarItem (DropdownListe) if (!dropdown){ aras.AlertError("The dropdown list was not found. This is an unknown error. Please contact your administrator."); return; } let newOptions = {value: "testID", label: "Project Test - Customer Test"}; dropdown.options = newOptions; dropdown.value = "testID"; // TODO: INIT oder REFRESH, ODER RENDER aras.AlertSuccess("The button has been refreshed."); When I am debugging this method I see that in my local scope the object this: Window exist. this.mainLayout.init seems to initialize the whole window but I only want to initialize my dropdown button. 3. The Question So my questions is if anyone of you did manage to new render a Command Bar Section Item in the header of Aras which is found under Command Bar Section: com.aras.innovator.cui_default.mwh_header? This would helps us a lot to gets this new feature Live in 3 weeks. I would appreciate every hint you can give me. Regards Patrick Ps.: Sry for formating ... I could not publish my very first discussion here without any disallowed html tags.Solved383Views0likes8CommentsDocumentation in German
Hello, We are a company operating over 2 continents, specialized in flower delivery, and some of our coworkers in Germany don't speak fluent English. Our current Aras installation is all in English, and I was wondering if there was a way to launch the software in a different language based on your location? If that's not the case, I was hoping to find documentation for Aras in German, as it may help our remote team get started. Thank you very much!182Views0likes2CommentsUnable to install project Management
Dear all, I am looking to install project management from ARAS Update. When I give the install path and other DB details and click "Install", it stands still. There is no error message received either. Please suggest if there are any pre-requisite applications I need to install. Of course, I have installed ARAS Innovator and Technical documentation module from ARAS UPDATE. Thanks in advance and appreciate your help here to get ARAS PM module installed.3.7KViews0likes1Comment
