Batch Delete Identity Memberships
Hello, We have used the batchloader utility to create new memberships in Innovator. It appears that removals are a bit more difficult due to safeguards in place for the system. What is an easy path forward in creating an AML script (or method) to accomplish this task? For example, we have 89 identities that had incorrect identity membership assignments. The goal is to remove existing memberships of an identity and add a different identity. --CorbinSolved216Views0likes2CommentsCall Where Used in Nash
Good day all. How can I call Where Used in Nash? We have a lot documents that we need to identify where they are used and it would be a real pain to have to go through each one, open it, select Where Used, and then figure out the contents. I have found the script in Client/Scripts, but I'm not sure how to call it. If someone has a better solution to getting this information I would love to hear it. Thank you.Solved3.9KViews0likes2Comments
