Even if the ResetTrigger of the LifeParameter of the DTC is No, the CurrentValue value can be changed to 0 in the PhysicalPart screen.
Hello, In Aras Innovator 14 Release 29, it is possible to change the CurrentValue value to 0 in the PhysicalPart screen even if the ResetTrigger for the LifeParameter of the DTC is No. > See 'Even if the ResetTrigger of DTC's LifeParameter is No, the CurrentValue value can be changed to 0 on the PhysicalPart screen.png'. The manual stated that it would not be possible to reset, so we read it as an expectation that the CurrentValue value cannot be set to 0. > Please refer to "Corresponding section in manual_DTC_UserGuideP152.png". Is this a defect? If not, could you please tell us what function is controlled by the Reset Trigger value? Thanks Fozia56Views0likes0Comments
