How to display database name on bottom in Innovator 12?
Hi community, I am right now playing around with Innovator 12 and have some trouble to differentiate two databases that run on the same server. In Innovator 11, the name of the database is shown at the bottom of the Innovator screen. This way it was always easy to see, which database is in use right now. Innovator 12 removed the database hint. When I want to discover the current used database name, I have to go to the menu in the bottom right corner, which means two additional clicks. The database information is not relevant for end user. But as admin I constantly move around between multiple databases. Is it possible to customize Innovator 12 so it will show the database information again? Are there any other ways to differentiate two databases on the same server? When having a full second server instance, it´s possible to use a custom logo for the second instance. Maybe we can do something similar on database level? I would be happy about any ideas that makes admin live easier in Innovator 12! Thanks! AngelaSolved7.4KViews0likes4CommentsWorkflow(?) Error - Conversion from type 'DBNull' to 'String' is not valid.
Good day all. I created a New Document Request (NDR) for our system. We are trying to test it out now. I can start the process, but the next person in line gets the Conversion from type 'DBNull' to 'String' is not valid error. There are four options for him to vote on; Assign Drafter - A, Assign Drafter - B, Reject, and Cancel. All options, except for Cancel, cause the error. I cannot figure out where this is coming from. I didn't have any problems when I ran this as an admin. I mirrored this request to our ECO process. I've checked the Lifecycle Map to make sure all paths have a role assigned. I looked at the Workflow Process and can't understand why this is happening. This shouldn't be caused by the notifications, they work fine when I start the process. Any suggestions would be grateful. Thank you.Solved4KViews0likes1CommentCommit the transaction half way through the code and continue the execution from there.
Hi Team, We have a scenario where we want to commit the transaction half way through the code and continue the execution from there. For example : 1. We are working on Background tasks implementation 2. Where we want to change the status [property] of the task from "new" to "in progress" at the beginning of the execution of task. 3. After that we execute some business logic. 4. Later we change the status of task from "in progress" to "done"/"failed" based on the result from 3rd step. What we have observed is Aras considers step 2-4 as a single transaction and commits that at once. But we want to see the change in status of task from new -> in progress [step 2] -> done/failed. [This change of status is must.] We found an reference from Aras Community, where we can use the "CCO.DB.InnDatabase.CommitTransaction();", to commit the transaction half way and continue from there. Questions : 1. Are there any repercussions/issues by using the solution that we have found ? 2. Is there any other way to achieve this ? Thanks !2.8KViews0likes1CommentLogin failed for user 'innovator' - MSSQL
I actually found a locked thread that answers this after 20 or so comments. No answer is marked as accepted. There are other very similar threads. None have a screenshot to tell the story of what to do. It ends up I had to enable mixed mode auth for the db. One comment from 9 years ago eluded to this, but with no "How-to", so: Right-click on DB name at root of tree and select "Properties". Enable Mixed-Mode as shown: After this is done right-click on DB name again and select, "Restart". Viola! Well, for me anyway. I really really really think the installer should have told me to do this.2KViews0likes2CommentsDB Lock
When I use applyAML, sometimes it will cause DB Lock. What conditions will cause this cause? By the way, I have the error message. When I applyAML =><AML><Item type='Activity' action='EvaluateActivity'><Activity>109890D287C24699A1EA639B921F3E18</Activity><ActivityAssignment>698758D37ACA41FDA7A23A3B412868C1</ActivityAssignment><Paths><Path id='3DD97DD4DAE948608796D353E71AF337'><![CDATA['Approve']]></Path></Paths><DelegateTo></DelegateTo><Tasks></Tasks><Variables></Variables><Authentication mode=''></Authentication><Comments></Comments><Complete>1</Complete></Item></AML> => System.Xml.XmlException: An error occurred while parsing EntityName. Line 4, position 203.2KViews0likes1CommentConnecting to Linked Server (External SQL Database)
Hello all, After many attempts and support of Aras Support, we are still unable to execute SQL Stored Procedures on an external SQL database. Context Aras Innovator Version 26 SQL Server 2017 Goal Execute a Stored Procedure on an external SQL server (NOT the Aras SQL server itself) from a C# Server Method. Attempts Making a connection using Microsoft.Data.SqlClient and the legacy System.Data.SqlClient. This involves using a connection string and executing a plain command. Used code: [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:f6796336-b0f8-4284-bca3-4d7d91f97dd5:type=csharp&text=Innovator%20inn%20%3D%20this.getInnovator%28%29%3B%0A%0Astring%20connectionString%20%3D%20%40%22Data%20Source%3DServerName%5CInstanceName%3BInitial%20Catalog%3DDatabaseName%3BUser%20ID%3DUserID%3BPassword%3DPassword%3BConnection%20Timeout%3DTimeoutValue%3B%22%3B%0Astring%20sqlQuery%20%3D%20%40%22Exec%20%5BServerName%5CInstanceName%5D.%5BDatabaseName%5D.%5Bdbo%5D.%5BStoredProcName%5D%20%40Variant%20%3D%20VariantValue%2C%20%40State%20%3D%20%27StateValue%27%2C%20%40ID%20%3D%20%27GUID%27%2C%20%40Test%3DTestValue%3B%22%3B%0A%0A%0Ausing%20%28Microsoft.Data.SqlClient.SqlConnection%20connection%20%3D%20new%20Microsoft.Data.SqlClient.SqlConnection%28connectionString%29%29%0A%7B%0Aconnection.Open%28%29%3B%0A%0Ausing%20%28Microsoft.Data.SqlClient.SqlCommand%20command%20%3D%20new%20Microsoft.Data.SqlClient.SqlCommand%28sqlQuery%2C%20connection%29%29%0A%7B%0Aobject%20result%20%3D%20command.ExecuteScalar%28%29%3B%20%2F%2F%20Executes%20query%20and%20returns%20the%20first%20column%20of%20the%20first%20row%0A%0Aif%28result%20%21%3D%20null%29%0A%7B%0Areturn%20inn.newError%28result.ToString%28%29%29%3B%20%2F%2F%20Logs%20the%20value%0A%7D%0Aelse%0A%7B%0Areturn%20inn.newError%28%22No%20result%20found.%22%29%3B%0A%7D%0A%7D%0A%7D] Result: Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding. Adding the external server as 'Linked Server' to the Aras SQL server. Then using innovator.applySQL() referencing the external database. Used code: [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:4f6ce192-841a-4134-8fa4-3bb5694c5708:type=csharp&text=Innovator%20inn%20%3D%20this.getInnovator%28%29%3B%0A%0Astring%20sqlQuery%20%3D%20%40%22Exec%20%5BServerName%5CInstanceName%5D.%5BDatabaseName%5D.%5Bdbo%5D.%5BStoredProcName%5D%20%40Variant%20%3D%20VariantValue%2C%20%40State%20%3D%20%27StateValue%27%2C%20%40ID%20%3D%20%27GUID%27%2C%20%40Test%3DTestValue%3B%22%3B%0A%0AItem%20response%20%3D%20inn.applySQL%28sqlQuery%29%3B] Result: This makes the browser client crash and we suspect another timeout in the back-end. Question Does anyone have a method (or workaround) to execute SQL on an external SQL server (NOT the Aras SQL server itself) from a C# server method? Best regards, Daan85Views0likes0Comments
