How do you import Excel BOM data into Aras Innovator open version?
Hello, I currently use the open, free version of Aras Innovator and am having difficulty figuring out how to store BOM data within the tool. I have seen from other posts that subscribers have access to a direct import functionality and also some kind of batch loader. For the latest free version of ARAS, what are the exact steps to import an excel file containing BOM data into Aras? Any help would be greatly appreciated.6.5KViews1like7CommentsARAS 31 soap-env:server authentication failed for admin authentication failed for admin
Hai, We have upgraded to ARAS 31 from 12. The migration is in progress. While login from application Its working fine. But while login from web API we are getting an error "soap-env:server authentication failed for admin authentication failed for admin" We have tried to give the password in MD5 hash format for username admin. But the error not yet solved. can anyone help us on this? Thanks in advance, Salini356Views0likes6CommentsAdd, Export & Import CAD Documents with attachments
Hello, In Aras Innovator 12, I'm trying to experiment with exporting of parts, which are having a CAD Document attached to them (which of course, has a file attached to it). I added the Part, CAD Document, File, CADFiles and Part CAD to the package and did the export process, yet, at the import process I'm receiving the message: [File Item cannot be added.]. I also tried to copy/paste the files from the original Vault to the destination Vault, but got the same message. I tried to move these files with backup operation and it was successful, but as I have to move only a few files, it would be better, if I can solve this with the export/import tool. Thank you! Chris6.7KViews0likes2CommentsHow to Import Data from Aras Innovator V11.Sp12 to V12.0
Hi, I recently installed Aras Innovator V12.0. I was using Aras Innovator V11.Sp12 where all my work was done. Now, i would like to switch to V12.0, I have few tables around 9 tables in which two tables of Manufacturing Process Plan and Operations, the rest are customized item types. How can i import the data of some of the tables which i need from V11.Sp12 to V12.0. Thanks.2.4KViews0likes0CommentsHow to synchronize the data of MPP_process plan with all its releationships with PostgreSQL Database
Hi, I'm a research student and we are doing a university project on PLM, we have an idea of storing and interacting the data of PLM systems with other systems like MES and ERP so we thought to create a central database through which every system will interact with other systems. Now we have to synchronize the data of MPP_process plan with all its releationships with PostgreSQL Database where the central DB is located, we wanna do this as a trail test to sync the data from Aras server into our Central Database and vice-versa. We are thinking not only to export the data for single time, but to Auto update of the data atmost real time. One of my friend from this Aras community suggested me to do by federation services but I don't know how to apply and how it works.! Or you have any other ideas how we can do? someone suggest me how to do. Thanks inadvance.5.4KViews0likes0CommentsPart Numbering System - Migration Environment
We are migrating from Enovia to Aras and most probably we will use a different part numbering system. Currently the part numbers are also used in our CAD and ERP systems. There is no integration. We just "synchronize" manually. Question: When we change to a new part numbering system, how do we manage this change in our CAD and ERP? How do we manage old and new part numbers to avoid any conflicts? Any ideas are appreciated.7.1KViews0likes1Comment
