SQL Server Reporting Services (SSRS) via HTTPS in Innovator Release 2023. How to fix?
Hi community, the release notes of Innovator 26 mentions following fixed issue: I-050277 Fixed an error that prevented Aras Innovator from connecting to SQL Server Reporting Services via HTTPS. I did a quick test in Release 2023 and noticed that I cannot create SSRS reports via HTTPS in this release. When executing the Report, I get following error message: "The provided URI scheme 'https' is invalid; expected 'http'. (Parameter 'via')". I assume Release 2023 still contains the bug that was patched with Innovator 26. Release 2023 removed the RSGateway.aspx that was previously used to connect to SSRS. Not sure how Aras calls the reports in the new versions. Does anyone know how to fix this one? I assume we need to customize the codetree, add some assembly binding or similar. But I have no idea so far how to do it. Thanks and best regards! Angela722Views0likes4CommentsHow to load aras 2023 dll with cpp host cli without native net core?
[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:4aacaea8-0c4c-471c-aefc-402fbf171d8a:type=text&text=%23using%20%22C%3A%2Ftemp%2Faras2023dlls%2Fbin%2FIOM.dll%22%0D%0A%23using%20%22C%3A%2Ftemp%2Faras2023dlls%2Fbin%2FSystem.Configuration.ConfigurationManager.dll%22%0D%0A%23using%20%22C%3A%2Ftemp%2Faras2023dlls%2Fbin%2FAras.Net.dll%22%0D%0A%0D%0Ausing%20namespace%20System%3B%0D%0Ausing%20namespace%20System%3A%3AIO%3B%0D%0Ausing%20namespace%20System%3A%3AReflection%3B%0D%0Ausing%20namespace%20System%3A%3AConfiguration%3B%20%20%0D%0A%0D%0A%0D%0Avoid%20arasDo%28%29%0D%0A%7B%0D%0A%20%20%2F%2F%20sample%20aras%20code%0D%0A%20%20System%3A%3AString%20%5E%20url%20%3D%20%22http%3A%2F%2Fdevaras2023%2FInnovatorServer%2FServer%2FInnovatorServer.aspx%22%3B%0D%0A%20%20System%3A%3AString%20%5E%20database%20%3D%20%22InnovatorSolutions%22%3B%0D%0A%20%20System%3A%3AString%20%5E%20user%20%3D%20%22admin%22%3B%0D%0A%20%20System%3A%3AString%20%5E%20password%20%3D%20%22innovator%22%3B%0D%0A%0D%0A%20%0D%0A%20%20auto%20conn%20%3D%20Aras%3A%3AIOM%3A%3AIomFactory%3A%3ACreateHttpServerConnection%28url%2C%20database%2C%20user%2C%20password%29%3B%0D%0A%20%20auto%20result%20%3D%20conn-%3ELogin%28%29%3B%0D%0A%20%20auto%20s%20%3D%20result-%3EToString%28%29%3B%0D%0A%7D%0D%0A%0D%0Astatic%20Assembly%20%5E%0D%0A%20%20LoadFromSameFolder%28Object%20%5E%20sender%2C%20ResolveEventArgs%20%5E%20args%29%20%7B%0D%0A%20%20%20%20String%20%5E%20folderPath%20%3D%20%22C%3A%5C%5Ctemp%5C%5Caras2023dlls%5C%5Cbin%22%3B%0D%0A%20%20%20%20String%20%5E%20assemblyPath%20%3D%20Path%3A%3ACombine%28folderPath%2C%20%28gcnew%20AssemblyName%28args-%3EName%29%29-%3EName%20%2B%20%22.dll%22%29%3B%0D%0A%20%20%20%20if%20%28File%3A%3AExists%28assemblyPath%29%20%3D%3D%20false%29%0D%0A%20%20%20%20%20%20return%20nullptr%3B%0D%0A%20%20%20%20Assembly%20%5E%20assembly%20%3D%20Assembly%3A%3ALoadFrom%28assemblyPath%29%3B%0D%0A%20%20%20%20return%20assembly%3B%0D%0A%20%20%7D%0D%0A%0D%0Avoid%20aras%28%29%0D%0A%7B%0D%0A%20%20%2F%2F%20put%20this%20somewhere%20you%20know%20it%20will%20run%20%28early%2C%20when%20the%20DLL%20gets%20loaded%29%0D%0A%20%20System%3A%3AAppDomain%20%5E%20currentDomain%20%3D%20AppDomain%3A%3ACurrentDomain%3B%0D%0A%20%20currentDomain-%3EAssemblyResolve%20%2B%3D%20gcnew%20ResolveEventHandler%28LoadFromSameFolder%29%3B%0D%0A%20%20arasDo%28%29%3B%0D%0A%7D] The exePath does not exist Assembly.GetEntryAssembly() returns a NULL Can someone explain me how to execute the added cpp sample code so I can load the aras 2023 dlls?174Views0likes2CommentsWhere and how does the new TOC Editor in Release 2023 store it´s data?
Hi community, In Release 2023 Aras replaced the classical TOC Access / TOC View ItemType tables with the "TOC editor". The two tables are not used anymore in Release 2023 and completely empty. When updating an existing db based on Innovator 12, we have to modify the imports to support the new way to config the TOC. Sure we can use the TOC Editor to modify the structure later, but I prefer the update process includes the correct TOC settings so I can reduce cutover time. Does anyone know, which table the TOC editor uses to store the new structure? Is it solely done in the "Client Presentations"? And which table is used to store the TOC editor "TOC View" symbol itself? It would be interesting to understand how the TOC editor itself works. But the ItemType obviously wasn´t named "TOC Editor" and so far I weren´t able to identify it. Thanks for any help! Angela950Views0likes2Comments
