eli_donahue's avatar
eli_donahue
9 years ago
Identity Circular Reference Check
This package contains a SQL stored procedure for import that helps check if your system contains any circular references in the identity structure.
Using the stored procedure, you can select the number of levels deep you would like to search to find your circular reference, which will allow you to clean up your identity structure.
This SQL is a modification of the Part BOM Circular Reference SQL procedure.
Interested in this project? Check it out on GitHub!
https://github.com/ArasLabs/identity-circular-ref-check
Contributors
Sean Coleman, Aras
License
Visit the project's LICENSE.md file for more information about licensing.
