8 years agoCommunity Manager
If you are using the most recent release of 11.0 SP12, you may be able to satisfy this requirement with the new Extended Classification functionality. You can see a demo of this functionality here.
If you are using an older version, the best way to approach this would be to contain all of the properties under one ItemType and then use different forms to display different properties. If you're not already using the classification field, you could define a custom classification tree with a different class for each Project. This would allow you to assign the Properties and Forms of your ItemType to a specific classification.
ananta_jena01_infosys_com
1 year agoIdeator II
Hi, My Manufacturer create button has disabled and I am not able any item coming under sourcing category Aras release 32
,Please help me. Thanks
- EricTD1 year agoIdeator II
Hi Ananta,
I think your question is of topic from the original question.
But long story short.
I think your permissions are not set in such a way that Innovator Admin can create a new Manufacturer.
For these kind of problems you best go to the ItemType (in this case Manufacturer) and then to the Permissions tab. Then open the permission to see which Identities can do what.
Hope this helps,
Eric
