9 years agoAccelerator III
I noticed that when I check the CM options from the admin account, if I go for example ItemType> PR > TOC Access tab > there is the identity 'all employees' that has access in the Change Management category. But if I uncheck the CM option PR , in the ItemType> PR > TOC Access tab > there is the identity 'ARAS PLM' .
So, in order the users be able to see the CM options changes, I should add the World identity too?
Thank you in advance!
