The "GetItemWhereUsed" only returns one level of the Where Used Results - I'd like to expand it for multiple levels like in the Where Used view. Any suggestions for getting the expanded results?
How many ItemTypes are involved in your task? 'GetItemRepeatConfig' would work when you don´t have too much ItemTypes.
https://community.aras.com/b/english/posts/special-aml-actions
It´s maybe possible to combine it with GetItemWhereUsed when you need a full coverage of everything, but I never tried.
Beware: The sample shown in the article looks "downwards", as you would do in a Bill-of-material.
You have to change the repeat property so it looks "upwards".
- Brooke5 years agoIdeator I
How can I change this so it looks 'upwards'? I've seen that action before but couldn't figure out how to reverse the direction.
Well, the query right now looks for the related_id item (downwards). You need the source_id item (upwards). So you have to change it in the 'repeat' attribute. But more important: Also in the 'select' attribute
Here's the query I have right now. It returns only one level. How can this be expanded further?
<Item type="Part BOM" action="get" select = "source_id, quantity" >
<related_id>
<Item type="Part" id = "{id}" action = "getItemRepeatConfig"/>
</related_id><source_id>
<Item type= "Part" repeatProp="source_id" repeatTimes="10" select = "item_number, name, classification, state, release_date, major_rev" />
</source_id></Item>
