ArG's avatar
ArG
Show form on promote
Usecase is as follows
need to validate field on promote if case of failure need to popup form(existing) and capture user input.
for validation, i tried with pre server method on lifecycle but popping up form not possible from server method.
Is there a way to achieve this?
Any suggestion/work around would really help
Thanks
  • Hi ArG,
    I see, I think this community blog post is what you're looking for then [emoticon:1435ff2429184e17bc948e4f19178e1e]. It explains how to create a custom modal dialog asking the user for text input as a client method.
    Best,
    Nithin
  • Hi ArG,
    You wouldn't have access to the form through a lifecycle since a server side method (required) would not be able to communicate with the client (which can call a popup action). You also would not be able to use a client method, as a replacement, since the pre method requires a server method.
    However, a workaround solution to this could be using the newError() method that returns a popup containing a string you can specify. This way if the user misses a field for a example, you can display this popup and require the field be completed in order for anything to be applied to the server.
    Best,
    Nithin
    • ArG's avatar
      ArG
      Hi Nithin,
      Thanks for reply.
      I understand that  client can't be called from server. but usecase is to show modal dialog to capture user comment. It is not popup actually. correction in question [emoticon:c4563cd7d5574777a71c318021cbbcc8]
      I am trying to modify javascript code present for on click of promote button, so that i can show required form based on my validation. Any idea on this ?
      Thanks
      • Nithin_Mahesh's avatar
        Nithin_Mahesh
        Hi ArG,
        Best,
        Nithin
