anhht-hue's avatar
anhht-hue
Search Parameter with date time
I have condition parameter search for ItemType Part like this (modified_on > 2019-04-11T00:00:00 and  modified_on <= 2019-04-20T00:00:00)
Case 1. When I new item AML  to search
<Item type="Part" action="get" select="*" where="[Part].modified_on &gt; '2019-04-11T00:00:00'  AND [Part].modified_on &lt;='2019-04-20T00:00:00' >".
----> it will return list Part with Part modified on 2019:04:05T00:00:00 -> Wrong, I dont know why the result is wrong
Case 2. So I change code to create new AML
<Item type="Part" action="get" select="*">
 <modified_on condition="gt">2019-04-11T00:00:00 </modified_on>
 <modified_on condition="le">2019-04-20T00:00:00</modified_on>
</Item>
----> It will return true results. So please help to find error in this case 1. Thanks so much
  • Hi Anhht
    I guess the error is because of the = in your first query (after &lt;)
    <AML>
    <Item type = "Part" action = "get" where="[Part].modified_on &gt; '2019-04-11T00:00:00' AND [Part].modified_on &lt;'2019-04-20T00:00:00'"></Item>
    </AML>
    Alternately, you can use below query also to get the expected results
    <AML>
    <Item type="Part" action="get">
    <modified_on condition="between">2019-04-11T00:00:00 and 2019-04-20T00:00:00</modified_on>
    </Item>
    </AML>
    Another Way
    <AML>
    <modified_on condition="gt">2019-04-11T00:00:00</modified_on>
    <modified_on condition="lt">2019-04-20T00:00:00</modified_on>
    </Item>
    </AML>
    Thanks,
    GK
    • anhht-hue's avatar
      anhht-hue
      Thanks so much @gkarasuser,
      Can I ask you another question? Is that AML not support operator <= or "le" ?
      By the way, I will try follow your answer. Thanks buddy.
      • Gopikrishnan's avatar
        Gopikrishnan
        Accelerator II
        Hi Anhht
        If you want to use "le" or "ge" it should be like
        <AML>
        <Item type = "Part" action = "get">
        <modified_on condition="ge">2019-04-11T00:00:00</modified_on>
        <modified_on condition = "le">2019-04-20T00:00:00</modified_on
        </Item>
        </AML>
        It is not working when we are giving it as attribute.
        Thank You
        GK
