Run Aras Report from Method
Good day all,
How do I run an Aras report from a Method? I have several reports that I have created in Aras (not MS Report Services) and I can't figure out how to run one from a method. I'm trying to create a Modal Dialog so the use can pick the report and information needed, then run the report. I noticed that there is an applyMethod (and others), but it didn't seem to work when I tried applyReport (I was hoping it would be that simple). Thank you for any help you can provide.
Hi Nathan,
I found this masterpiece in my valuable collection of fine arts that I have built up over the years:
var qry = new Item('Part','get');qry.setID('DEAE331032E2495DA9C9BBB6CA4583EE'); //Id of the context itemvar reportQry = new Item('Report','get');reportQry.setID('FB8CA61BE45E46DE9E4346BB653398C2'); //Id of the Report -> Multilevel_BOMvar report = reportQry.apply();aras.runReport(report.node, '', qry.node);The code is from 2017, so maybe it requires some update to current codestyle.
But you can also look at the Aras-Methods that trigger Report items, e.g. Method 'cui_ivicb_reports_click' . This Method shows a more flexible variant, that can also call Self-Service-Reports.
