lpignedoli's avatar
lpignedoli
Ideator II
Method for event OnAfterUnlock
I want to promote an Item state when user unlock it. I create a simple LifeCycle: "New"-->"Released" I habe write this method on the server event "OnAfterUnlock": Innovator inn=this.getInnovato...
  • Gopikrishnan's avatar
    Hi
    onAfterUnlock action will have info about the ID and Type of the item type. We need to fetch information again to get the item number and state information.
    // First Line is a debugger. You can debug server methods. Please have look at https://community.aras.com/b/english/posts/debugging-in-aras-innovator
    // if (System.Diagnostics.Debugger.Launch()) System.Diagnostics.Debugger.Break();
    var queryItem = this.newItem(this.getType(), "get");
    queryItem.setAttribute("select", "item_number,state");
    queryItem.setID(this.getID());
    queryItem = queryItem.apply();
    if (!queryItem.isError())
    string itemnumber = queryItem.getProperty("item_number");
    string state= queryItem.getProperty("state","");
    if ( state != "Released" )
    CCO.Utilities.WriteDebug("IP_ScadDocsPromote","Item = "+itemnumber +" State = " + state);
    this.promote("Released","");
    return this;
    Thank You
    GK
