Hi Eli, thanks for the quick reply!
- When I pressed save or done on an Item I used to get a null error message, (now I dont see any error in Aras but the save still fails/ gets aborted)
- I'm not quite sure what that means, but when I save an item, a versioning attribute is incremented and I can also create new revisions of the item
- My Code:
var id = this.getID();
var type = this.getType();
MyDll.MyFunction(id, type);
return this;
The basic idea is that I get the updated id of the changed item and feed them into my custom function. Inside of MyFunction I do an async AML request against Aras <AML><Item type="type" action="get" where="[Item].id='id'" /></AML> and then push the result to a different service. This works fine if I test it with a static id but if I try to use this.getID() the changed item does not get found and the AML returns null as result.
Small update, I found the function "CCO.DB.InnDatabase.CommitTransaction();" and if I call this before MyFunction everything works like I expected. Is this fine or is there a better way to do this?
