Is your custom form a some item form or a custom dialog? The dropdown is some item property or just list of values?
- Sathish3 years agoCreator I
The custom form is a standard HTML page and not a dialog.
Then in the HTML page, from where i open the searchdialog, below code is used[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:3ef7092b-3234-478d-939a-ce8f57a5282b:type=javascript&text=async%20_openSearchDialog%28%29%20%7B%0A%09%09const%20returnValue%20%3D%0A%09%09%09await%20this._topWindow.ArasModules.MaximazableDialog.show%28%27iframe%27%2C%20%7B%0A%09%09%09%09aras%3A%20this._aras%2C%0A%09%09%09%09itemtypeName%3A%20this._selectionSetItemType%2C%0A%09%09%09%09type%3A%20%27SearchDialog%27%2C%0A%09%09%09%09sourceItemTypeName%3A%20%27vm_SelectionSet%27%2C%0A%09%09%09%09sourcePropertyName%3A%20%27custom_variabilityitem%27%2C%0A%09%09%09%09parameter1%3A%20%27%25variability1%25%27%0A%09%09%09%7D%29.promise%3B%0A%0A%09%09return%20returnValue%3B%0A%09%7D]
I write the below code in onSearchDialog event of the property. I want to use the parameter1 value in the 'onSearchdialog' event.
[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:c4014cff-d5c5-4afb-84c6-88a71ec3c2d6:type=javascript&text=var%20customParam%20%3D%20inArgs.parameter1%3B%0Avar%20Filter%20%3D%20%7B%7D%3B%0AFilter%5B%22dvl_variabilityitem%22%5D%20%3D%20%7B%20filterValue%3A%20customParam%2C%20isFilterFixed%3A%20false%20%7D%3B%0Areturn%20Filter%3B%0A]
- alaxala3 years agoCreator III
You can use the itemContext property of the search dialog parameters. The type of the itemContext is Node, you can set it properties or attributes and it will be passed to onSearchDialog method as inArgs.itemContext.
