Hi Hargul,
I think your error is not related to your use of getID(). The error specifies that your code doesn't return properly. Make sure your method ends with the return of an item, or if you only need to return a string you can return inn.newResult("STRING");
For what you're trying to achieve, I am not sure I understand the use case. Are you trying to modify the document and set the ID to a different property? With more context I believe I could better help you here.
AJ
- Hargul_Sidhu2 years agoCreator I
Hi AJ, thanks for replying. The issue is that there is no property of the Document item that has a "ID" . The id are just the Document item_number(screenshot below). I want the unique IDs, the value in <id> tag, to be displayed in the search grid. I don't want to change the current Data Source of the ID property. I want to add a new property, say GUID, that will show the unique id in the search grid.
- asebastian2 years agoCommunity Manager
Interesting! That's a new use case. I'd recommend:
Create a new property on Document called GUID.Create an onAfterAdd server event which sets the GUID when a new document is created.
Attach the following method:
[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:176e2284-e941-45b6-9e39-c6ee21b38dc7:type=text&text=var%20inn%20%3D%20this.getInnovator%28%29%3B%0D%0Athis.setAction%28%22edit%22%29%3B%0D%0Athis.setProperty%28%22GUID%22%2Cthis.getID%28%29%29%3B%0D%0Athis.apply%28%29%3B%0D%0A%0D%0Areturn%20this%3B]
This will set the GUID for all Future documents. If you want to do it to existing ones you'd have to get them all in a method and loop through them. It's a one time operation to set the ID > GUID.
AJ
Thanks for the prompt reply AJ Sebastian Unfortunately, things don't work on my end.
I added the method but I don't get the ID in the GUID column in the search grid, screenshot below. Am I missing something?
