frank_guarino_murata_com's avatar
1 year ago
How to update grid values without running .apply() (I want to update it only in the frontend and not post it)
Hello, There is a relationship grid row that I would like users to mass edit. I so far configured a method to appear in the CUI along with the functionality of having multiple rows highlighted, ...
  • Hello, I found out the answer to this.
    JavaScript Aras method, aras.setItemProperty() is what can perform the front-end sided operation.
    The parameters descriptions are found when you dive into the method. Ensure that srcNode is an Item.node, and itemTypeNd is the item "Item" of the item, and also should be passed as an item.node. Passing them as item.node is important to have .selectSingleNode() available directly, as that method is called directly on the parameters and will return an error such as 'method selectSingleNode()' doesn't exist.
    I configured this to be run on an action, and performs much faster than running a .apply() on each record. It also shows the updates on the screen in real time, so once the operation is complete it will be apparent as you can see the grid change.
    Best Regards,
    Frank
