How to setup system for Development Purpose
- 7 years ago
Hi plmlearner,
The first step is installing an innovator instance on your machine. This guide goes over how to install Aras Innovator 11.0 onto your machine. Once your instance is installed, you'll be able to customize it to your liking.
Creating custom logic within Innovator is normally achieved with Methods, which are snippets of C#, VB, or JavaScript code. The Innovator client has its own method editor, so a standalone IDE is not necessary. If you do wish to use Visual Studio, Aras has published a project which allows you to edit Aras Methods with Visual Studio. This GitHub repository contains that project.
I'd also recommend taking a look at some of the blog posts by Aras Labs, as we've published many blogs to help people get started writing their own code within Innovator.
AJ
