Zachary's avatar
Zachary
Ideator II
How to Set RelationShip field value result as onFormPopulated ?
I have a itemtype call 'Part' ,
Part has a field call 'part price'  (type is decimal)
Part has a relationship call Part_detail
Part_detail has a field call 'RP price' (type is int).
I need "part price" to have thousand separator, but it is only for displayed, and does not need to be in the database after save
so I use onFormPopulated event to set
code as :
document.getElementsByClassName('part_price')[0].value = originalValue.replace( RegExp, '$1,'$2');
It is work !
but I need "RP price" to have  thousand separator ,too !  It is relationship  and has no onFormPopulated event to code
What should I do to have the same effect as "part price" (thousand separator just for show , not need to save in database )?
and where I can edit relationship DOM ?
    • Zachary's avatar
      Zachary
      Ideator II
      HI Angelalp !
      This way will change all the fields in ARAS, I only need to change specific fields, I hope there is a more suitable method for me.
      thank you!!
      • Hello Zachary,
        You can try adding one federated property on relationship item type,also on that relationship item type add server event "OnAfterGet" and update that property using this.setProperty(PropertyName, Value);
        this will have all items in relationship so use this.getItemCount() to get all item and update specific item using for loop.
