How to set 'Simple Search' as default search mode in relationship grid instead of 'Hide Search Criteria'?
- 7 years ago
Hi Aaba,
the only way I have come across to change this is to change the relationshipsGrid.html in
<Path to Innovator Installation>\Innovator\Client\scripts:
Somewhere it will say
RelationshipGridSearchContainer.prototype.defaultSearchMode = "NoUI";
You can change the "NoUI" to "Simple", which should do the trick. Remember to increase the filesRevision in Innovator/Client/web.config at the very bottom for your changes to the client code tree to be grabbed immediately.
However, this changes this behaviour for all ItemTypes. If you want it for a particular ItemType/Relationship only, you'd probably have to use some client side method to implement this (unless there is some way to configure this that I simply haven't seen yet).
Hope this helps,
C
