How to pass additional custom parameters in Form call?
Hi Community,
I want to launch a custom Form from an CommandBarMenu CUI event. Users can select multiple items in the grid and then click the CUI button. Then a form shall open up in which users can do certain operations with the selected items.
I want to pass the id´s of the selected items to the launched Forms. But I right now didn´t find an elegant way to pass the idlist or multiple items. I right now create a temporary item, but I am not very happy with the solution. I somehow think that passing custom paramters to Forms should be possible. I just don´t know how.
Does anyone of you know a solution? My main problem is not the actual passing of the custom parameters. But I don´t know how to retrive it later.
Here´s my current code;
var idlist = options.selectedRowsIds;var inn = new Innovator();
// Create temporary item to pass idlist (workaround!)var tempItem = inn.newItem("Part");tempItem.setProperty("_idlist",idlist);
// Launch Formvar topWnd = aras.getMostTopWindowWithAras(window);topWnd = topWnd.main || topWnd;
var params = { title: 'do something', item: tempItem, formId: "9336D7E4DD244391AEC9593DD8A5D85B"' aras: aras, //innovator: this.getInnovator(), dialogWidth: 1200, // set width int dialogHeight: 600, // set height int content: 'ShowFormAsADialog.html',idlist: idlist <<<<<<<<<---------------------------------------- // is it somehow possible to pass custom parameters with the form to avoid the tempItem? And how to I get it?
Thanks for any ideas!
Add the below code to your Aras method. Hope this helps
wnd.ArasModules.Dialog.show('iframe', params);-----in your ShowFormAsADialog.html---------------------
addd this line
var args = window.frameElement.dialogArguments; // get the params from Aras method
